winnie said:They are beneficial for reducing the size of transformer needed for a given KVA, or motor for a given horsepower.
-Jon
If you require an induction style motor operating faster than 3600 rpm, you need higher frequency. I've seen the 400 hz running routers in industrial applications, WITH APPROPRIATE MOTORS. A 2 pole motor will spin about 24,000 rpm, a 4 pole about 12,000 rpm. This application is great here. The "more power in smaller frame" camp is telling part of the story ... thermal limits get you, but higher speed at the same torque is more power ... at 60HZ, a 10HP 3600, 5HP 1800, and 3HP 1200 might all be in a 215T frame.POWER_PIG said:Ok, Thx
I looked and looked, and came up with minimal information. Im wondering what the heck the advantage of theses systems would be?
I believe that modern power supply technology, with the highly efficient DC-DC converters (operating FAR higher than 400 Hz), have replaced the rotating sets of old. Just as with motor speed control inverters, the 3 phase line is rectified then chopped as required.zbang said:Some mainframe-type computers (like Amdahl, NAS, or Fujitsu) run on either 400 or 415 Hz . The basic idea is to make the power supplies smaller and block disturbances from hitting the system. When last I saw some of these, they used Edpac MG sets in sound-insulating cabinets sitting in the computer room.
russ said:I know that some of the land power run to airplanes is 400 hz
I've heard there is 400 hz equipment on board to reduce size and weight.
I won't swear to any of the second statement above.
