410-66(b) This article is to prevent the installation of insulation over top of all non-ic rated recessed fixtures but is there any maximum height? We have non-ic recessed cans installed in a acoustic ceiling and the general contractor installed insulation up in the bar joists (above the cans). The electrical inspector has failed the contractor because of the insulation installed above the cans. Could the fixture be boxed in and/or is there a minimum clear distance the insulation has to be away from the top of the can. I am just dealing with the top of the fixture. The code gives a 3" min. distance but the inspector says that is from the sides, not the top.
