Flicker Index
- Pac NW
- Lights
"For indoor locations at other than dwellings and associated accessory structures, fluorescent or LED luminaires that use double-ended lamps and are equipped with ballasts or LED drivers that can be serviced in place must have a disconnecting means either internal or external to each luminaire"
a screw in light bulb or PL-C lamps are "single ended" and the common fluorescent lamps are double ended, as well as LED drop-ins. Now, when it comes to integral ballast LED lamps in tube shape but wired such that its powered using the two pins on one end, is it still "double ended"? If not, is this the reason one end feeding is a common?
