In the 2002 handbook the highlight under 440.21 states that an air conditioner with a nameplate that reads (max fuse size only) restricts the unit to fuse protection only and does not cover its use with circuit breakers which would require fuses ahead of or a fused disconnect to be installed instead of a no fuse at the unit.I do not see this passage under 440.21 in the 2002 codebook,,,,,is it somewhere else? does the handbook take presidence?
