Re: 4500 sq.ft house requires what size panel?
sceepe,
Why did you only use 80% of the capacity of a 150-amp panel. In a residential occupancy there are usually no continuous loads, and if there were, only that portion of the load that was continuous would need to be figured at 125%
Just a factor of safety I have grown use to using because I distrust diversity factors. You're right, not required.
I believe in giving the customer what they pay for and not one ounce more.
Your making my point for me. Mr. Homeowner got the absolute minimum. The load calcs in the NEC are not used to determine the optimum service size. They are used to determine the MINIMUM service size. I wouldn't want the smallest possible, garage, sewer line, hvac, or service entrance. I'm sure you would not either.
the ?ELECTRICIANS? of this forum are agreeing that the original service was installed to small although it passed.
I am not an electrician. This forum is not just for electricians. I did not mean to give the impression that I thought the original install was in error. Just a poor design
What I see is a home owner that wants something for free per say a larger service. What I am hearing is that it should have been GIVEN to him from the start.
The electrician makes this possible by installing an oversized panel and knocks himself out of work. He gave work away for free.
No one is saying it should have been given to him. The value of the larger service should be reflected in the price of the house. The electrician should make more to install a larger service. Granted you would make a lot more if you could install the bare minimum, rip it out and install a larger one later on.
However, the homeowner admitted he did not do his homework. He thought he was getting a house with bunch of extras and turns out he got the bare minimum electrical service. Its like buying a Ferrari with a volkswagon engine. Would you be arguing that he should bring in the car for a bigger engine if he needed to go over 55 mph.
Maybe we see thing differently. I believe in maximizing customer satisfaction instead of profit? In my experience, it proves more profitable in the long term
