Thank you for this.The rest of the notes from that project, switching 12) wye/delta motors from low volt to high volt and changing the overload relays to suit.
Take special note of the second drawing, where it says to swap the winding connections, when using the wye/delta control, otherwise the motor will change directions at the switchover, at full speed. Could be ugly on a large motor.
I have a cooling tower fan that uses a run forward/ run reverse setup that was built in the 50's using a similar set up as sketched with the three starters. I have no wiring diagrams and every component is in its own NEMA 7/9 enclosure.
