480-240 single phase ground point
dm9289
Industrial Maintenance Electrician
Pennsylvania
Industrial process repair/ maintenance Electrician
On a single phase 480-240 v transformer supply utilization equipment that does not carry a neutral.
Would it be proper to ground the X2-X3 junction like a typical 120/240 system.
Would it be proper to ground X4.
Would one be more advantageous than the other in this application
Please see pic
dm9289
Pennsylvania
I was trying to think of fault current and to my imperfect thinking I thought either could be ok.
If I am correct you recomend X2-3 junction
LarryFine
Henrico County, VA
Electrical Contractor
An end-grounded arrangement would double the line-to-ground voltage, increasing fault current.
I do, for all the usual reasons.
dm9289
Pennsylvania
Thank you very much great explanation. I felt both gave a path, but did not think of the increased fault current on corner ground.
dm9289
Pennsylvania
The other reason for grounding the center tap (X2-X3) is to limit the line to ground voltage to 120. This is because lots of things that might work on 240 do not like 240 line to ground due to transient protection, etc.
Thank you
