I have seen a couple post from this forum about corner grounded delta. They have answered some of my question but not really give an answer or solution to the problem I am having.
Story:
We are a small prototyping and engineering firm that ust to be a general machine shop with welding, cnc and fabrication throughout our plant. We have found a great niche and have been growing for a couple years. The building is quit old and after calling and testing the incoming service this is what we have. After the past week of research have found out that Incoming from POCO is 480 3 Phase Delta. In the electrical room it is switched to 480 corner grounded delta where one leg is carrying the neutral and a load. This has never really been an issue in the past since most of the equipment was welders, pumps, motors, and manual lathes that really never had VFDs or servo amplifiers within the machine.
Over the past couple of months we have started purchasing new CNC lathes and mills. Brand new Haas VF5ss is being installed. Install tech from Haas is testing incoming before turning machine on. Phase to Phase is all great 480 479 478. Then leg to ground 480 479 0. This is coming from the corner grounded delta that is feeding the buss. Not sure if it is B or C phase that is corner grounded. This normally would not be to big of an issue however the Haas machine VFDs and servo amplifiers probably require the 277 for surge overload and if a storm hits or we get a fault in on leg it will have the potential to send 480 surge instead of the 277. Any ideas on how to solve this or who to call that might have knowledge of possible solutions. Every electrician I call tell me I am dealing with a unicorn and that they cannot help. Machine is running fine and we cut power during hot part of the day in case POCO starts increasing voltages or if potential for storms are present. I maybe freaking out for nothing but I dont want to fry my machine. This is a huge investment for my small company. Any advice would be greatly helpful.
