littlerice40
Hi I am an electrical apprentice and Im looking for a little guidance. I was at a job with my journeyman this last Friday adding a 480 V panelboard. It was a quick install and we had time left so they asked us if we could move and wire a small 480 V-4 Amp grinding table they had. So we moved it and realized there were no 480 V recepticles on that wall. So my journeyman noticed there was a 480 V bussplug near by that was feeding another small machine so he used it to feed this grinder. He ran the conductors through the same conduit to the same 4 square box as the other machine. Then, he ran the conduit from that box to the disconnect for this new grinder. He wired up the line side and then hooked a recepticle below the disconnect to the load side of the disconnect switch. The fuses in the Bussplug were 20 amp fuses existing and the old machine was about 8 amps I believe. He didint change those and he put 7 amp fuses in the disconnect for the grinder. He energized the grinder after restoring line power and it blew the fuses. He said it was the grinder and we just left it, he told the people it was a bad grinder so he unplugged it and the other machine still worked so we left. Is that really the case, could there be a short in the grinder? I mean when he checked incoming v in the grinder discoonect before plugging the grinder in the fuses held but once he plugged it in, boom. Should he have ran a seperate conduit for the grinder and not double tapped the lugs in the bussplug? I am curious, he doesnt explain things well to me, maybe because he doesnt know. Any help or info would be great. littlerice40
2-7 amp fuses opened and 2-20 amp fuses in the buss plug opened.
