Fulthrotl
~Autocorrect is My Worst Enema.~
- E
C-10 friend of mine has a need for someone who can hot tap a bus
with 4/0 copper. location is in so. calif.
work amounts to landing a ground and three hots in an underground
fed POCO pull section. ground is on bottom of pull section, pre punched
bus bars on top of section. you'll need to hipress on a lug, and bolt
it to the bus bars, one 4/0 per phase. so, 4 landings total, three hot.
health care facility, ahead of the main, POCO service xfmr is fused
about 200' away on secondaries. 3,000 amp 480 bus, fault current
is going to be up there a ways. so don't screw up would be the operative
word.
m.v. herzog was on deck to do it, and they had to cancel. i've got a friend
who is a MV cable splicer, and excellent craftsman, and he's busy and
can't do it.
i've got the equipment, skill set, and am not available in the time frame
he needs. figure a couple hours work for two guys, about $3k.
anyone interested, PM me, and i will put you in touch with the fellow.
as for NFPA 70E, compliance is up to the person doing the work.
i've not seen the site, just a verbal description. i'm just putting it out
there if someone wants a quick little job for a fair piece of change.
randy
word.
can't do it.
randy
