meternerd
- Athol, ID
- retired water & electric utility electrician, meter/relay tech
What would be wrong with swapping them in the disconnect. None of the ungrounded conductors are identified color wise. I figured it would be the better option because after each contactor every connection is numbered. The second winding starts two seconds after start
Did you read my post above yours? If conductors are not color coded brn org yel ABC or numbered, they should be. Doing it at the disconnect means that on top of the disconnect you may have ABC CW, but at the load connected to the bottom (top of contactor), you swapped wires and now have ACB CCW. If everything you work on is clockwise, then life is much simpler. What if your contactor is CW, but the one for the motor next to it is CCW? If you have only one 3 phase load, it doesn't matter, but that's not usually the case. You may have conveyors, fans, other pumps, etc. that are wired to the same source. If you swap yours at the disconnect, it may end up CW at the contactor. Now the next device may be CCW at the contactor because that guy decided to swap his rotation the same way you did. Now poor old electrician ME comes along, disconnects the motor but forgets to write down how it was connected. Well...50/50 chance, right? On many pumps, such as shaft driven turbine pumps that may have 500' of shaft between the motor and the pump, reverse rotation can unscrew the shaft couplings and you'll find yourself with a pump at the bottom of a well that has no way to be recovered. These types are removed by pulling them up by the shaft. Others have seals that will be destroyed if run in reverse. That said....my background is in the utility industry, both electric generation and water. I was taught that you always wire motor circuits ABC clockwise all the way to the bottom of the starter. Rotation is wired at the motor. That way, any work requiring disconnection of anything ahead of the motor can always be hooked back up correctly. Just the way I've been doing it for more years than I care to count. I understand that you can reverse rotation anywhere you have all three phases, but why not make it easy on everybody? Just kidding about yelling at you though. I'll just stomp away and pout, or "rat you out" to the boss.
