Rob2025
- Toronto, Canada
- Electrician
Hi
I would like to learn more on 400V-3ph Motor connections to VFD driver.
In general, I found there are only 3 connections U, V, W available on VFD Inverter terminals for the motor. If there are only 3 wires connected from VFD to the motor and as there is no Neutral terminal available from VFD, then does it mean Motor is always connected in a Delta configuration?
Is there any way we connect the motor in Wye or Star configuration to VFD?
