We are converting 32 nonspeed controlled conveyors to VFD Control. We're installing two cabinents which contain 16 VFD units each. We are debating whether to run all the control loops together seperated from the 480 line/load conductors. They are a 12V pulsed signal and go down to a set of NO points in the Buckets from where of course the 480V line/load conductors will pass through too so there will be some chance to create a little space between the two once they are inside the motor contro center. Has anybody done a similar project? The cabinent wiring would look much cleaner if the control wires were run with the 480V and this what the tech wants. There will be two 1 1/4" EMT conduits for each cabinent. I believe seperation is best since the conductors are #18 single stranded MTW conductors. Any opinions? I'll probably call the manufacturer in the next few days and report back their ideas too. Thanks!
