I have a new lighting installation using 480V metal halide fixtures, and was planning to use emergency/exit lights at all the exit doors. These fixtures are 277V. Instead of running a separate 277V circuit to these fixtures, is it NEC compliant to tap one of the "hots" from the 480V fixtures, and pull just the neutral from the panel? All of the lights will be fed from the same 480/277V panel. The only problem I see comes from having a 2-pole breaker sized to protect the 480V load, but using one of the poles to protect the extra 277V load.
