mm007hm
New member
- San Francisco Bay Area
Situation:
A large PV solar array, installed over water in a lake or pond.
We have been retained to advised on shock hazard / corrosion issues.
System has multiple 480 ~ 600V DC (not AC) 150 amp armored feeder cables running from the array, to shoreside DC > AC inverter. The client wants to know how big an area they need to enclose around the array to prevent trespassing / unauthorized personnel from entering an area that may be subject lethal voltage gradients if a worst-case fault to water were to occur.
Can anyone help calculate what the size the 'Danger Zone' would be with a full fault at 480V 150A into fresh water?
None of us in the Marine Industry have any data to calculate size / strength of the field around a fault from DC+ to water.
Deaths from 120 / 240 V AC faults to water are well known, any voltage gradients that subject a swimmer to over 30mA can kill, but we have found little or no data on hazards from high voltage DC, other than one expert who commented that based on a Coast Guard study, it take approx 3x the DC current to be lethal as AC. We are of the opinion that there is no way to define the danger zone to to infinite variables with salinity, conductivity, etc, but we need some sort of ruling or opinion from a higher authority to bolster our case.
Any help appreciated.
