- Wisconsin
- PE (Retired) - Power Systems
And what percentage of total US installations do you think these represent?We have many 480 high leg open delta here, mostly feeding limited loads.
It can't be much. For all the same Kwire & I share statewide, I don't ever remember seeing a 480 hi leg delta and only a couple corner grounded. Two ungrounded.And what percentage of total US installations do you think these represent?
Likely less than 1%.And what percentage of total US installations do you think these represent?
You certainly have the occasional open delta bank for limited load like a center pivot only or maybe a smaller capacity well here or there?I don't ever remember seeing a 480 hi leg delta and only a couple corner grounded.
Then I stand by my statement they are extremely rare.Likely less than 1%.
Just not in my little corner of the country. Might still be only a small percentage of the services supplied, but enough of them are around that if you do work on farms you will run into them. The commercial/industrial only guys may never see them, especially those from outside the area. Some of them don't even know what 240 high leg delta is.Then I stand by my statement they are extremely rare.
This is a national forum, not one focused just on Nebraska.Just not in my little corner of the country. Mi
Electric driven center pivot irrigation machines are always 480 volt three phase.What for? Must be farm thing,
@kwired I think it rains more out east where these guys are from, probably not as much irrigation, Here in Oregon there is probably an area the size of Wisconsin in eastern Oregon with 480 volt hi-leg open delta irrigation services all over the place.Just not in my little corner of the country.
The other thing is we have the water. Wisconsin I suppose may have quite a bit of surface water but not sure what the have for underground aquifers. That along with crop genetics they can get higher yields but those won't do so well on "dry land" fields if they don't get a lot of water through key parts of the growing season which makes this area a great place to grow those particular varieties. You don't spend the money for irrigation if you don't intend to use it correctly to get maximum yield.@kwired I think it rains more out east where these guys are from, probably not as much irrigation,
Places with oil wells may very possibly see delta systems as well. IDK what size pumps or what voltage is common but is a rather limited load just like these irrigation services are with possibly no 120/240 needed.240/120 3ph 4W delta systems, very common.
480/240 3ph 4W delta, I’ve only seen mentioned in textbooks and a couple of times in Internet forums. I see no purpose for it. Someone needs 480 3 phase and a LITTLE BIT of 240 single phase without needing 120 single phase too? What for? Must be farm thing, but even the farms here in California don’t get that from any of the utilities that I have ever come across.
