I have a system on which two 480 volt 1.5HP hydraulic pumps cycle on and off, causing very large counter emf spikes on the 480 volt power. These spikes are coupled through a step down transformer that powers a 120 volt panel. The spikes then damage sensitive equipment on the 120 volt system. I'm thinking of installing an isolation transformer at the 480 volt pumps, in hopes this will isolate the spikes from the system. I have confirmed with a scope meter that this is the source of the problem. Any suggestions??
