Some info needed on commercial systems. I do mainly resi.
IN GENERAL
For commercial, what is the most common AC Voltage in the USA?
How common is 208 Vac Wye?
If, as I read, 208 is the most common commercial voltage why are "all" solar inverters 480V/277V?
Is it standard practice in comm. solar to install a transformer to get to your particular AC V?
SPECIFICALLY
Right now, I am tasked with re-powering an (E) 28 kW-DC, 15 yr old system with an (E) 208 V Wye Xantrex inverter (30 kVA) and separate ground mounted isolation transformer.
I am having a helluva time finding a good inverter match.
To make it harder, The DC circuit is combined on roof into a single #2/0 conductor circuit.
So, I need a single inverter (not two).
I also need a single DC input on that inverter that can handle that amperage. Many 30 kW inv.s seem to have multiple inputs.
IN GENERAL
SPECIFICALLY
