paul32 said:I'm talking about the boxes.
LarryFine said:Unfortunately, I don't know of anything larger than 4-gang also, as far as plastic is concerned, with one exception: there is an 8-gang box available, but it may not be rated for line-voltage use, as there are no cable clamps. Otherwise, I'd go with two boxes either stacked or side-by-side.
Added: You can also ise the 1-piece metal multi-gang boxes that use these covers:
Paul, once i get over a 4 gand I stack my switches because it gets to difficult to remember what switch does what-- so for a 6 gang I will stack two 3-gang boxes. By the way once you get over a 6 gang the plates have to be custom made and cost somewhere around $40 or so for a plastic plate.paul32 said:Maybe I wasn't clear enough. I'm talking about the boxes. NM boxes only go up to 4 gang. I can find wall plates. I said a single wall plate do mean a way to do a set of switches together, like a 6 gang box (that doesn't exist as far as I know). So is there a way to do the box besides putting 5 or 6 of the 2x3 gangable metal boxes together?
Not necessarily: $10Dennis Alwon said:By the way once you get over a 6 gang the plates have to be custom made and cost somewhere around $40 or so for a plastic plate.
Yeah--- you didn't have 8 gangs in there. We were talking basic colors and style not brass and stone or what not.celtic said:Didn't you guys see my first posting with prices from $3 - $200?
Dennis Alwon said:We were talking basic colors and style not brass and stone or what not.
LarryFine said:Not necessarily: $10
I haven't had to do this yet, and was just trying to see if there were other options. I had thought of the time to assemble, and the cost, and wasn't sure yet how to mount them. Allen also said they tend to separate?celtic said:Is there an issue ganging up the metal boxes?
allenwayne said:Those are what I like to use they are a bit costly but the time it takes to gang LC boxes together and never mind if when they drywall they knock them to hard they tend to separate, also the 1 piece multi gang box is alot simpler to mount.
paul32 said:I haven't had to do this yet, and was just trying to see if there were other options. I had thought of the time to assemble, and the cost, and wasn't sure yet how to mount them. Allen also said they tend to separate?
celtic said:- BUT...if you use 2 of the side mounts at either end, attached to the studs, it will be a nice secure, properly seated box.
