It can be done with many parallel loads, or just very low impedances, using larger-gauge conductors and high-current devices. Ohm's Law still applies:How can 5 volts produce 1000amps?How can you get the resistance that low?
Actually, 12.6V is the open circuit voltage of a 100% charged automotive 12 volt lead acid battery... 6 cells at approximately 2.1 volts each. Voltage above that is charging voltage of the alternator, which can approach 15 volts on some vehicles. 14.4 volts is considered the level at which outgassing occurs.While only delivering 12v (13.2v to 13.4v, actually)
Yep. I have one of them. It's output is rated 2 ? 5,000W into1 ohm loads (or 1 ? 10,000W bridged into a 2 ohm load).Modern high-powered car amplifiers actually contain DC-to-DC power supplies that use near-household-amplifier voltages, but the input is still many amps at 12v.
As Larry says, Ohm's Law applies.How can 5 volts produce 1000amps?How can you get the resistance that low?
Unfortunately, they don't.Those speakers have to be a minor marvel of engineering. You would think they would self-destruct.
It still is.The picture I posted a link to (taken during the build stage) is one half of of a 20,000A system we made last year.Currents of 1,000 amps or more at only a few volts used to be common for electroplating plants).
You could drive that with a 1KHz signal and weld with it. I once read an article about someone doing that with a Mark Levinson amp.Yep. I have one of them. It's output is rated 2 ? 5,000W into1 ohm loads (or 1 ? 10,000W bridged into a 2 ohm load).
As for current draw...833A
Recommended fusing for each of the four power inputs is 250A.
Not at 1 kHz. It's a D-class dual mono block (translation: 2-channel subwoofer amp) with an upper frequency cutoff at 250 Hz.You could drive that with a 1KHz signal and weld with it. I once read an article about someone doing that with a Mark Levinson amp.
Yep... but it's not constant. So being a non-continuous load, fusing at 100% is permitted. :grin: But 833/4 is not a standard fuse rating, so I have to go with the next higher standard rating of 4?250A :grin::grin::grin:If that current was constant, the fusing wouldn't be NEC compliant.![]()
I would assume that the opposite is true as well in the case of high voltage and low current. The high voltage has a very large source inmedence thus limiting the current to a very small amount.
A stun gun is an example that comes to mind discharging 10,000V with a low current in the mA range?
Most of the high current stuff we make is for anodising and plating - typically 35V and 10kA dc.Many industrial spot welders operate at 5 volts and up to 3000 amps.
The 5 volt electrode supply is stepped down from (usually) 480 volt three phase.
