Electriman
- TX
Are we required per NEC to have 50/51 G on every breaker that is greater or equal to 1200A per NEC or is it only for service disconnect?
Instantaneous and time-overcurrent ground relay.What is 50/51G?
What is 50/51G?
210.13 Ground-Fault Protection of Equipment. Each branchcircuit
disconnect rated 1000 A or more and installed on solidly
grounded wye electrical systems of more than 150 volts to
ground, but not exceeding 600 volts phase-to-phase, shall be
provided with ground-fault protection of equipment in accordance
with the provisions of 230.95.
215.10 Ground-Fault Protection of Equipment. Each feeder
disconnect rated 1000 amperes or more and installed on solidly
230.95 Ground-Fault Protection of Equipment. Ground-fault
protection of equipment shall be provided for solidly grounded
wye electric services of more than 150 volts to ground but not
exceeding 1000 volts phase-to-phase for each service disconnect
rated 1000 amperes or more.
The smart-ass answer would be “No” because it’s 1000A, not 1200A...Are we required per NEC to have 50/51 G on every breaker that is greater or equal to 1200A per NEC or is it only for service disconnect?
So what do you think?
BTW, it says 1000 A in these provisions, not 1200 A.
