emahler said:Indoor usage...anyone know if one is manufactured?
i've found a couple in the 50'+ range, but they are all outdoor, and gas powered... really need an electric unit...
emahler said:the problem we have is access...not even sure if it's a feasible plan...we are looking for an alternate plan to scaffolding...
situation is a few runs of conduit on a stage (engineers will need to sign off on the weight) in a theater...runs go up about 55'....each run consists of between 2-4" EMT and 2-4", 2-2 1/2"& 2- 2" EMT's....
the only scissor lifts that i have found, average about 15,000 lbs....
i have a sneaking suspicion that we will be working off of scaffolding...
emahler said:a boom lift actually makes life a little more difficult than scaffolding due to the # of conduits and their size. with a scissor lift I can put more material on it and save time.
growler said:I don't know about that. I ran about 14 thousand ft of 2" EMT down at the main post office in Atlanta off a JLG boom lift. There was no way I could have used a scissor lift ( to many obstacles ). If you know how to use it those things are great.
A 60 ft. scissor lift is a monster. A 60 ft boom is much smaller and easier to deal with in tight places. I'll take a lift over scafflolding any day.
This is just one man's opinion. I don't like climbing.
iwire said:I have spent a ton of time up in lifts of all types.
IMO running any conduit out of a basket type lift stinks, no room for material, no room for bending. Sometimes you have to do it that way but if at all possible I use a scissor lift.
emahler said:but, i'll look into it...how did you handle material? how many feet of emt at a time could you take up with you?
growler said:I built myself a rack so I could take up about 6 sticks of 2" each trip. [/COLOR]
