Alwayslearningelec
- NJ
- Estimator
Can that be moved with electric pallet jack? I know it's a very heavy piece of equipment and not certain if always "rigged".
We've used them too but I'm not a big fan for large equipment. Using a motorized jack to do the pushing makes handling the big stuff a two man job. They also can crush the enclosure when you jack them up for very heavy stuff.We always used Rol-a-Lifts for that type of work. Typically to set on a pad, we would use three. One at the far end, and two on the sides at the end closest to the pad. At the pad, we would use RMC as rollers, as suggest by Rob.
You do have to be sure you are on the frame. Never had any opportunity to use a motorized jack.We've used them too but I'm not a big fan for large equipment. Using a motorized jack to do the pushing makes handling the big stuff a two man job. They also can crush the enclosure when you jack them up for very heavy stuff.
