wwhitney
- Berkeley, CA
- Retired
So this receptacle clearly states not to install in a single gang box or mudring. I would take that to mean it requires a double double allowance (4 total):The code section refers to receptacles wider than a standard single gang box. But based on the fact that you CAN install it in a single gang box, the double volume allowance would be correct.
279-S00
Black - 50 Amp, 125/250 Volt, NEMA 14-50R, 3P, 4W, Flush Mtg Receptacle, Straight Blade, Industrial Grade, Grounding, Side Wired, Steel Strap
Whereas as this product looks similar but none of the literature on the website addresses the question. It has central mounting holes on the yoke. Do we assume it's OK for single gang mounting, or assume not?
279-S00
Cheers, Wayne
