50AMP/1PH/208V Service for Apartment
That 1000 VA fridge and 840 VA wine cooler may draw that for like 5 minutes when in defrost. But otherwise probably draw much less in normal run mode.
It probably will, but usually you need to show 2 small appliances. So I usually select the fridge and microwave
Actually refrigerator is supposed to be included with the 1500VA SABC's, and no additional load needed to be accounted for.
Now if you run a third (or more) SABCS you need additional 1500 VA for each one. You must have a minimum of two is all that is required.
