thelonelord
- Burlingame, CA
Is it acceptable to put a 50A receptacle on #12 20Amp circuit if the load does not exceed 16amps? (tesla car charger)
Please note that that only applies to a single receptacle on a circuit that has nothing else connected to it.Yup. 210.21(B)(1).
Yup. 210.21(B)(1).
Welcome to the Forum.![]()
Is this a DIY question or related to being a building inspector.
Any electrician would know the answer
Mind Boggling. Tesla owners, but they scrimp on the charger outlets.I have a client who has a 50 amp plug Telsa charger and uses an adapter to plug it into his 30 amp dryer outlet without issue. The cord does not get warm.
They are using the Tesla 30 amp adapter or a homemade adapter? With the Tesla 30 amp adapter the car will only charge at 24 amps max. If using a homemade adapter the car will try to charge at 40 amps on the 30 amp dryer circuit.I have a client who has a 50 amp plug Telsa charger and uses an adapter to plug it into his 30 amp dryer outlet without issue. The cord does not get warm.
I have no idea what the comment about the cord getting warm means. Why would the cord get hot when connected to a lower rated circuit?
I know, You are just saying it works.
Just to mention it, as Sheldon Cooper would, "nauseous" is used to describe something that causes nausea; you were nauseated.I was nauseous for the rest of the day.
I didn't say he was scrimping on charger outlets. He was using the adapter for several weeks while he was waiting for me to install charging outlets. I have since installed three: One outside his office next to his parking spot, and one in each of his two garages at two different residences.
BTW, he gave me a ride in his model 3. It went from zero to 60 in like 2 seconds. Scary as hell when you're not expecting it. I was nauseous for the rest of the day.
I wouldn't say someone would have never made it then, I would have enjoyed zero to 60 in two seconds much more 30 years ago then now.You would have never made it my era, driving pre 1970 model vehicles that would also do zero to 60 in like 2 seconds, because back then you also had the fear of the frond end falling out from underneath it to contend with on top of the acceleration rush....
JAP>
