We are wiring a dental office. Specifically, the underground to the chair's quad receptacle (located under the chair) is normally run with PVC under the concrete with (4) #12s (hot,neutral & 2 grounds). The inspector required steel conduit because one of the grounds had to be the conduit. How is this diffrent then 12-2 mc hg with its cu. wire and alu. wire?
