- Illinois
- retired electrician
If the transformer is to be 4X, then yes, the panel boards and other electrical enclosures should be the same.And how does this hurt anything? Any painted or galvanished sheet metal in the same area will also rot away eventually. It is not just transformers. Are you planning to require SS for all sheet metal boxes out there? Or just transformers?
I have seen all kinds of sheet metal boxes that rotted away outside nowhere near a dock or pier.
In any case. No inspector has the authority to make that determination unless it has been granted him or her by the actual AHJ. I am not aware of many (if any) AHJ that have given that power to individual inspectors.
The AHJ can certainly make that determination.
Are you saying the rotting away of the electrical enclosure is not any type of safety hazard, especially when located where there will be people around, such as this dock?
The manufacturing plant that I do a lot of work in, requires the use of NEMA 4X enclosures for everything that is outside or in their wet process areas.
