I'm attempting to bid a new VFD conversion project, where the customer is changing out a 4160V 2500HP motor for a 575V 2500HP pump motor, and adding a step down XFMR, power filter and VFD. (Lower voltage VFD much cheaper) The primary 4160V is fed from a fused switch (old starter), and will feed the new transformer. I'm trying to size the fused service disconnect, and the problem is I have no motor nameplate data because it hasn't been ordered yet. Rule of thumb is one horse=one amp for 575V motors, but I'm new to this voltage. Any ideas? Wouldn't the disco and time delay fuses need to be 4000A? Starting current shouldn't be a big issue, unless at a later date the VFD gets bypassed- it happens. Thanks for your opinions.
