kingpb
- SE USA as far as you can go
- Engineer, Registered
Wow, I'm (almost) speechless.
Perhaps it would be better to leave it at that............Cheers!
Maybe you missed the title of the post: "5HP motor conductor - easy question."
That's where "design" comes into play.Just make sure you don't get too much VD at the motor peckerheads or you will have longer starting times. Another problem with using the smallest allowable size is when the specific installation is far from the source and the starter is located at that far end!
