mark puentes
New member
- New Jersey
Does anyone know where I can find information in the code book about the use of these adapters in a hotel. If they are legal. They plug into an outlet and a fastened with the center plate screw.
I disagree. An intelligent user knows that no more power is available just because one of these devices is used. It is only an ignorant, or uneducated, user who makes the assumption you are charging.Originally posted by bphgravity:
I am not a big fan of these devices. They simply make the user assume that more power is available at the outlet location because more plugs can be inserted. This is obviously not the case.
Originally posted by racraft:
Do you actually know of any?An intelligent user...
It is my opinion that a duplex receptacle outlet is intended for use with two cord-and-plug connected appliances or equipment and no more. The use of extension cords, multi-adaptors, or plug strips should not be used unless designed with internal overload or overcurrent protection installed.
These should only be used for temporary needs and limited to 90 days use. Call your local fire marshall and see what their official opinion on the use of adaptors and extension cords is. I think you will be suprised how many emergency calls are from electrical fires and cord melting at these locations that use these devices.
