RogerRoger25
- Exeter
Does anyone have information on how to calculate the secondary line voltages for this type of transformer? Information generally would be gratefully received!!!
How about an explanation of how you are using this and why you need to know? Because if it's just the 6 phases you want to know about, that's easier to describe than the 9 possible connections available.Does anyone have information on how to calculate the secondary line voltages for this type of transformer? Information generally would be gratefully received!!!
Got a diagram?Does anyone have information on how to calculate the secondary line voltages for this type of transformer? Information generally would be gratefully received!!!
Do you think he means hexaphase?How about an explanation of how you are using this and why you need to know? Because if it's just the 6 phases you want to know about, that's easier to describe than the 9 possible connections available.
Got a diagram of a forked star?6 phase
ph-ph voltage = ph-neut/gnd voltage
Hexaphase is commonly used for six-pulse rectifiers for high current low voltage rectifiers. There is one device (SCR typically) in each leg. The merit is that you have just one semiconductor voltage drop as opposed to two with a full wave rectifier. The devices are subjected to a higher PIV but if the system is just a few tens of volts that is not usually a critical factor.That lower diagram is something I was aware existed in theory, but have never needed to implement. 6 phase (hexaphase) as shown in the upper diagram on that page, used as an input to a 12 pulse rectifier, yes. But the "forked wye" thing is not necessary for that. Still, there are people who sit around thinking about this sort of stuff for all kinds of off beat uses.
The only dealings I’ve had with hexaphase is with MAR’s and that’s going back to when Noah built the ark.
You mean mercury arc rectifiers?
We did a bunch of them, 70kA total, for an anodising line. the supply was from a couple of local ONAN focal transformers supplying 660V and our hexaphase units had auxiliary 400V tap to feed the phase control firing circuits.Yes, but the transformer has a few extra windings for ignition and excitation.
Not the kind of thing where you can afford to get your sums wrong.
I did mean archaic. Thought you might see the funny side.Yes, but the transformer has a few extra windings for ignition and excitation.
Does the second diagram in post #7 pertain?Hi Guys,
Apologies for the delayed response, this is a question presented to me in an exam and I had no idea about it. Reference material is very hard to come by, hence my question on here.
The primary can be either delta or star three phase as far as I am aware and the secondary has a total of 9 windings.
Vague I know.......
Well, I desinged it so I suppose the answer is yes.Do You have the calculation method?
But what do you want to calculate?
