cvirgil467
- NewYork
anyone know if using the six service rule compromises arc flash protection?
thanks
c
thanks
c
I shoud have been more specific.
Does the hazard risk increase when using the six switch service rule in lieu of a main circuit breaker?
Many of my customers will not allow fuses to be changed in six service rule equipment except when a power outage has been taken.
If there is no OCP between the xfmr and the disco, either one or six, the IE or HRC should be the same for each and that would require a calculation to determine the level of hazard.
hey ZOG.........it's for you....
Yes.Jim,
Will you explain this a little more? I don't understand. Are you saying the PoCo must kill the transformer to change one set of fuses even though opening the knife blades removes power from the fuse holder?
