frizbeedog
- Oregon
stickboy1375 said:
Lame pic. Stick
We expect better from you. :grin:
...wait, was I supposed to click on it.
Edit......oops.
stickboy1375 said:
frizbeedog said:Lame pic. Stick
Edit......oops.
highendtron said:Man, I love this forum!!!!( except fpr the dog song which would have been ok if one would have just been able to watch her walk her dog...but we had to listen to her miss all the high notes, oh well).
highendtron said:I would be reluctant to run mwbc with one nuetral.
highendtron said:....I would be reluctant to run mwbc with one nuetral.
LarryFine said:What was confusing to some was saying that only a properly-connected MWBC is a MWBC. That's echnically correct, of course, but it's easy to misunderstand that whether a given home run is a MWBC or not can depend on how you feed it, and with no other changes.
Not only has MWBC wiring been common for decades, I use them whenever possible, especially including when extending existing circuits. I'll combine 2-wire circuits and use 3-conductor cable as much as possible, even if it means one 15a and one 20a circuit.
In other words, if there's an even number of 15a circuits, I run half that many 14-3's, and the same with the 20a circuits. If there's an odd number of one of them, I'll run one 2-conductor cable. If there's an odd number of both, I'll use a 12-3 and one will be a 15a circuit.
LarryFine said:If there's an odd number of one of them, I'll run one 2-conductor cable. If there's an odd number of both, I'll use a 12-3 and one will be a 15a circuit.
hank you!frizbeedog said:echnically?
Sorry, you still have time. :grin:
peter d said:How dare you! What is the homeowner decides to change the breaker after you leave? :roll:
LarryFine said:hank you!![]()
I'll send in the breaker police.peter d said:How dare you! What is the homeowner decides to change the breaker after you leave? :roll:
LarryFine said:If you want a serious answer, splice a piece of #14 onto the #12 close to where it enters the box.
I agree with Dennis that because of the dangers with losing a nuetral in single phase services, I would be reluctant to run mwbc with one nuetral
divied the volts with the ohm's to get watts?should that say amps?frizbeedog said:
zappy said:divied the volts with the ohm's to get watts?should that say amps?How did he get the watts from that?It's late i must be missing something:smile:
Step 5. Determine the power consumed by each appliance: P = E2/R
Hair Dryer: P = 76.82/11.3 = 522 watts
Television: P = 163.22/24 = 1100 watts
Yes that is what i was thinking.So can't you take the amps and x it by the volts to get the watts?frizbeedog said:Note that He used E2/R= W or (P)
You must be thinking of E/R=I (amps)
If this is the part your'e thinking of.
Look at your ohm's law wheel. :smile:
