martin reid
- Gilman Hot Springs, CA 92583
Ventricular fibrillation from electroshock, and arc flash, are the two most acute dangers of the US Electrical system, with both these "built in" from the start. Particularly, 60 Hertz line frequency is universal, with the last exception of a remaining 25 Hertz system finally closed down. Studies and tests long-since done uncovered the fact that the heart is most sensitive to ventricular fibrillation at just about 60 Hertz, but not hugely better in this regard at 50 Hertz. A study also uncovered that as one drops the AC voltage from 120V down to 50V, 60 Hertz, the ventricular fibrillation risk goes away. The conclusion is the type of system regulated by Article 647 - the 60/120V "balanced power" 'sensitive electronic equipment' system affords the safest electricity-based energy conveyance system on the entire planet other than straight DC. The 60/120V system is the only alternative system affording operation of 99.9% of existing 120VAC utilization equipment however, using the same wires in the same old walls. Currently Article 647 restricts utilization of 60/120V to only "sensitive electronic equipment" supervised applications, where, if universally applied to the residence and the workplace instead, could result in the near future with residential and office general-use branch-circuits which are essentially free of electrocution risk. I am looking for anyone with expertise or knowledge of electric-shock related information, who can impart this information, which will enable me to further substantiate the fact that needless electrocutions continue to occur in residences and in some cases, office occupancies which would be utterly prevented by widespread use of the 60/120V Edison-three-wire balanced power system, and wish to develop a thread intended to explore the ramifications of such a system. An example of a ramification are lampholder screw-shells, whereby if fed by a 60/120V system, the screw shell would be "energized" with 'house current' that would expose probing fingers to a 60VAC shock if any part of the person were contacting ground or metal parts. IF we are "stuck with" the extremely undesirable line frequency of 60 Hertz, I believe it is the responsibility of the electrical industry to provide mitigation to the unfortunate hazard which has tragically cut the lives of many children and adults short over the last 100 or so years. I'd like to hear from anyone with specifics regarding any event which resulted in a fatality which involved any 120V-to-ground general-use branch circuit (whether single phase or polyphase), which could have been prevented had the branch circuit been a 60V to ground "balanced circuit" with 2-pole GFCI branch-circuit protection -- in other words, set up exactly per Article 647 but applied to residential or commercial ordinary use. I'd like to hear from anyone who has an informed opinion about how we can evolve the present dangerous system to one which will eliminate hazards to children and ordinary people who make accidental or foolishly deliberate contact with electrical energy conveyance systems and suffer the consequences. My reasoning is something CAN be done about this and that we don't have to accept it just because someone made a very bad choice 100 years ago to reduce lamp flicker.
