dereckbc said:It would depend on the Laptop Power Supply technology being used. If it is Switch Mode Power Supply it may work because a SMPW converts the AC line directly to DC. The problem could/would be the AC line filters installed from L-G, L-N, and N-G would be designed for 60 Hz and could burn up at the higher frequencies.
If it is a linear power supply (using a step-down transformer) it would not likely work at all, or the output voltage would be way to low.
