How do people define "rigidly attached" for a light fixture above a hot tub? 680.22 B3
Is a pendant that hangs from a flexible cord rigidly attached provided it had a proper canopy and fixture box?
Not IMO. The fixture/box would need to be securely fastened directly a building, not a cord pendant. Maybe a RMC pendant could be allowed.
(3) Existing Installations. Existing luminaires and lighting
outlets located less than 1.5 m (5 ft) measured horizontally
from the inside walls of a pool shall be not less than
1.5 m (5 ft) above the surface of the maximum water level,
shall be rigidly attached to the existing structure, and shall
be protected by a ground-fault circuit interrupter.
