Re: 680.43(B)
Yes and remember this fixture is measured above the maximum water level. Although the tub has a high water mark the question is what is the maximum water level? The way I see this is, put a water hose in the tub and turn water on, when water can no longer be put in the tub with out spillage then and only then have you found the maximum water level.
