asian195
- Kent, WA USA
Got a question about the location of the initiation device, specifically for one and two family dwellings. Code requires it to be located outside in readily accessible location.
Most of the PV systems i see are utility interactive and shut down when the utility power is disconnected.
So if the service panel and inverter are both located inside the garage, does there need to be an external rapid shut down initiation device? Let's assume no 3rd power source (generator, batteries, energy storage, etc)
I'm trying to think as a first responder. If they pull the meter or turn main breaker off (which is already located inside the dwelling) then rapid shutdown is initiated. So why the external switch?
Sent from my SM-G920P using Tapatalk
