DerrickM
- Billings, Montana, USA
I am installing a pole mount system here at our campus.
Here is where I am at:
I am using the new C-250 Enphase Microinverter as the basebuilding voltage is 480/ 277V.
I thought this was a good idea to use the higher voltagesource to help reduce voltage drop issues that could arise as our PV array isapprox. 350’ away from our electrical source.
I am installing an outdoor rated cabinet/panelboard thatwill be used solely for the distribution for solar arrays, this is only about 25' away.
The goal is to have a total of 8 pole mount systems, eachpole consisting of 12 modules and 12 microinverters, and installing 1 polearray per year for the next 8 years.
I like the microinverter system for the ease of addinganother branch circuit to our outside (within site) panelboard each year.
This brings me to my question:
Article 690.13 (A) requires me to have a PV disconnectingmeans installed at a readily accessible location on the outside of thebuilding. This I will have, as my outdoor rated panelboard will be with in siteof the pole mount arrays. I will be using the 3 pole circuit breakers for this.
I am struggling with 690.13 (D) which states that themaximum number of disconnects- switches or circuit breakers, allowed is 6. Why6? My goal was to have a total of 8 systems, each one having its own 3-phase,480 volt circuit breaker, all installed in one panelboard.
What am I missing with this code rule?
Thanks in advance.
Thanks in advance.
