Rex Hungerford
- Seattle
- Electrician
I am designing electrical onelines for residential homes that contain Hifi and Video equipment. I am very conscious the grounding and design a single point where all grounding electrodes on site (concrete encased, rods, cold water, chemical, etc) all come to a single bonding point. I have a lot of customers wanting to add solar now.
NEC 490.47(B) in short says additional grounding electrodes shall be permitted to be connected directly to the PV module frame or support structure.
In my mind, this is a parallel ground path to earth. The Frames and support structures are bonded to the primary grounding electrode system on the property. And now to a new rod or plate in the earth.
I am assuming this is a safety design for some installations. Say your only existing grounding electrode is a Ufer. If a lightening bolt hit the array, the energy would go to the Ufer and could flash heat the concrete surrounding the rebar ground in the footer and shatter the footer. An additional rod from the frames to earth might take some of the energy and save the homes foundation.
This is my assumption why this might be done. Is this correct?
Are there other reasons why a solar installer might want to land additional grounds on the property and only connect them to the frames or support structure of the solar array?
