Hopewell51
New member
- Raleigh NC USA
With an 8 panel Pole-mounted grounded PV system located less than 100 ft. from the Main Service panel, per 690.47( D) I am required to set a grounding electrode in close proximity to the Pole-mounted PV System.
Do I need to bond the electrode at the Pole -mounted PV disconnect to the Main Service Panel grounding electrode and also run a equipment grounding conductor ground to the Inverter ground buss?
