ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
"An array grounding electrode(s) shall not be required where the load supplied by the array is integral with the array."
That language is confusing to me; what does it mean by "the array"? By the definition in 690.2 the array is only the DC part of the system, so wouldn't the inverter be the load supplied by the array? If that is so, any time the inverter is "integral" with the array, whatever that means...
Integral: adjective 1. of, relating to, or belonging as a part of the whole; constituent or component: integral parts.
... you don't have to have a grounding electrode on the array. Any time an array is connected to an inverter, that inverter is "of, relating to, or belonging as part of the whole" PV system, is it not?
