jaggedben
- Northern California
- Solar and Energy Storage Installer
The bleed down kit is a resistor that bypasses the DC disco. It allows the voltage that is trapped between the switch and the optimizers to equalize in under the ten seconds dictated by the NEC. My understanding is that the residual voltage is on capacitance in the optimizers and the inverter, and opening the DC disco takes the capacitance in the inverter out of the circuit.
I'm by no means sure of this, but my understanding is that the bleed down is for the capacitance of the inverter, not the optimizers. I'm more sure of this: if the DC switch is opened it will bleed down the inverters and not the optimizers, because it's installed on the inverter side of the switch.
