PowerMan2020
- virginia
- electrician
Splicing 6-3 Romex in an 42cu. 11B.
(Romex coming into the back of box with a NM-B clamp connector and an EMT set-screw connector also coming into the side of box for the exit of the splice).
Curious to see what you all would use between 3M Performance Plus Wire Connectors (B/G+) (Rated for a max of 2 #6's) OR 2 Port insulated taps (#4-14)?
Wire nuts would be around half a dollar each while the taps would be $10 each x 3.
