I would insist on stacking a 4 gang with a 3 gang on the top. A 7 gang plate will cost you dearly-- I bet about $35-$50.Custom home HO wants to put 7 switches togather I have never seen a 7 gang decora plate or box. The most I have seen is 6. Is it possibble and please don't say gangable metal cutins . Website would be halpful if you know of a product. Thanks.
Do you need inside or outside corner-plates?someday I wanna have a custom home with a room where the switches go all the way around the room, but i haven't been able to find a switch box that goes around the corner.
Gangable metal cutins.
"99, I asked you not to tell me!"[/center]
That's one way. In a big house we did, I found ways to separate the larger bunches of switches into logical groups so I ended up needing nothing larger than 4-gangs.But seriously, how else would you make a 7 gang box with readily available and inexpensive parts? I know most of the better supply houses carry the 7G box and ring mentioned in this thread earlier, but if you can't get that what do you do? Gangable metal cutins.
Instead of a 7-gang, how 'bout using some stack switches?
Yeah but then you have to consider box fill. A feed in and feed out and 7 lighting loads (not taking into consideration 3-ways) thats 27 times the multiplier depending on whether you do your lights in 12 or 14 guage.
1 for the ground
18 for the hots and neutrals
8 for 4 yokes (stacks switches for three yokes and a single switch for the fourth)
27 x 2 = 54 cub. in (14 guage)
27 x 2.25 = 60.75 cub. in (12 guage)
I only see one yoke on that switch. And I doubt there's 7 seperate circuits in the OPs situation. Most switches would be on the same circuit, so the pigtails wouldn't count.
