7 Switches to control same light fixtures in large room
rc7288
Wisconsin
I have a large room with 7 doors and would like a switch by each door to turn the lights on/off. How many 3-way, 4-way, etc. switches will I need to do this? A wiring diagram would also be helpful if possible. Thanks.
Sierrasparky
USA
Electrician ,contractor
2 3 ways and 5 -4way.
You might want to consider electronic switching, Masters and remotes to minimize all the wiring.
dkidd
here
PE
dkidd
here
PE
I don't think that is a code compliant method for residential anymore, You need to have the neutral at the switch box or a way to add it in conduit. I believe.
It's subtle, but the diagram does show that the neutral is in each cable at each box.
This is better.
JFletcher
Williamsburg, VA
2 3 ways as first and last, 5 4 ways in the middle. See post #5, just add another 4 ways to it.
Must be one heck of a room to want 7 switches controlling the same lights.
Fulthrotl
~Autocorrect is My Worst Enema.~
"You want to consider electronic switching, Masters and remotes to minimize all the wiring."
i fixed your sentence. i'm crediting your account 1 word.
seriously. 7 lutron picos will get it done. you can even do dimming.
register picos with master. peel and stick on walls. smile. go home.
Sierrasparky
USA
Wow 1 word credit. How many do I need for a prize?:happysad:
boy am I leaving myself open on that one!:angel:
