I read this as if the load trasfer automatically the generator must be big enough to handle the transfered load, unless automatic means are used to shed loads.
GENERLINK.COM
Is a item my POCO is selling it goes into the meter socket and acts as an automatic transfer switch. You plug your portable generator into it. Is this leagal if your portable is not big enough to run all the transfered load.
Does the code asume if you have a automatic transfer swith your generator will start automatically. The system would be residental but I still believe you need to follow Article 702
GENERLINK.COM
