gar
- Ann Arbor, Michigan
- EE
081118-1148 EST
iwire:
The KWH meter is reading the cumulative energy consumed. For each small increment of time the energy is measured (watts times seconds) and that is added to the previously accumulated value. The adding is accomplished by the mechanical counter (the gear box and pointers). On a mechanical watt-hour meter the rate of rotation (speed - rpm) of the disk is a measure of the instantaneous power being used.
The instantaneous power is V*I*PF. The power measured by the rate of rotation of the KWH meter will differ from the calculation of V times A by whatever the PF (power factor) is.
I can not directly measure power factor, but I can measure VA and watts and from this determine PF.
There is a relationship between VA and watts but it depends upon the waveforms and their phase relationship.
iwire:
