Alwayslearningelec
- NJ
- Estimator
About how long could you do one through a 6-8" concrete slab? BTW, we sometimes need to have a guy coring and one on the floor below.
Also never know when X-ray of slab is needed when coring or trenching concrete . Sometimes specified or notes on drawings and sometimes not.Depends partially on the size of and how much rebar. Should be able to drill that hole in an hour.
8”What is the hole diameter, or did I miss that?
Mark
The diamond core bit cuts fairly quickly through concrete but it cuts very slowly through rebar especially if you have #8 or larger rebar. I've core drilled hundreds and hundreds of holes and the most important thing to do is to use as much water as possible. Guys often scrimp on the water which causes the bit to cut slowly and bind up due to the debris not being flushed from the hole. Then when they get the bit stuck they might spend an hour or so just trying to get it out without damaging the hole, that's if they can even get it out (that's another story).How would rebar cause an issue ?
How would rebar cause an issue ? Sure it would just curious in what ways
make sure to be careful when drilling on suspended surfaces inside of buildings. we had a job at a grocery store where GC didn't check for utilities or Posttension cables in the slab. It cost them over $500,000 after smacking through 5 of them and figuring out what they were. Make sure to call in locates or x-ray before preforming the work. older buildings are notorious for hiding utilities in slab.Also never know when X-ray of slab is needed when coring or trenching concrete . Sometimes specified or notes on drawings and sometimes not.
Thanks. Why so much $$?make sure to be careful when drilling on suspended surfaces inside of buildings. we had a job at a grocery store where GC didn't check for utilities or Posttension cables in the slab. It cost them over $500,000 after smacking through 5 of them and figuring out what they were. Make sure to call in locates or x-ray before preforming the work. older buildings are notorious for hiding utilities in slab.
These cables run through the slab all the wat to the other side to compress the concrete. the compression of these cables "post pour" add strength to the floor. often if these are hit they have to either repour that section and dig out those lines. Not to mention that there can be bundles of these together. imagine how difficult that can be, while avoiding all the rebar, all the way across the pour.Thanks. Why so much $$?
